Hi there,
I've got the error after completed installation, here is some error message on login page as following;
Error in query [SELECT * FROM nodes WHERE nodetype=1 ORDER BY nodeid] [Table 'zabbix.nodes' doesn't exist]
mysql_fetch_assoc(): supplied argument is not a valid MySQL result resource[/htdocs/zabbix/include/db.inc.php:607]
mysql_free_result(): supplied argument is not a valid MySQL result resource[/htdocs/zabbix/include/db.inc.php:609]
Error in query [SELECT u.* FROM users u WHERE u.alias='guest' AND ((u.userid BETWEEN 000000000000000 AND 099999999999999))] [Table 'zabbix.users' doesn't exist]
Error in query [SELECT s.* FROM sessions s WHERE s.sessionid='' AND s.status=0 AND ((s.userid BETWEEN 000000000000000 AND 099999999999999))] [Table 'zabbix.sessions' doesn't exist]
Error in query [SELECT count(u.userid) as user_cnt FROM users u] [Table 'zabbix.users' doesn't exist]
Error in query [SELECT * FROM config WHERE ((configid BETWEEN 000000000000000 AND 099999999999999))] [Table 'zabbix.config' doesn't exist]
Error in query [SELECT u.userid,u.attempt_failed, u.attempt_clock, u.attempt_ip FROM users u WHERE u.alias='Admin'] [Table 'zabbix.users' doesn't exist]
Error in query [SELECT nextid FROM ids WHERE nodeid=0 AND table_name='auditlog' AND field_name='auditid'] [Table 'zabbix.ids' doesn't exist]
Error in query [INSERT INTO auditlog (auditid,userid,clock,action,resourcetype,details, ip) VALUES (,0,1295895076,3,0,'Login failed [Admin]','10.10.1.2')] [You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '0,1295895076,3,0,'Login failed [Admin]','10.10.1.2')' at line 1]
Error in query [SELECT * FROM profiles WHERE userid=0 AND ((profileid BETWEEN 000000000000000 AND 099999999999999)) ORDER BY userid ASC, profileid ASC] [Table 'zabbix.profiles' doesn't exist]
