I try to export and import a group of servers.
Export is ok.
Import fails with message:
ERROR: Import failed
* No permission for Template [001_Apache]
Where we can check what is happening ?
Best Regards,
Adail Horst
Debug Info:
******************* Estatísticas de script *************************
Tempo total: 0.14809
Limite de memória : 128M
Uso de memória : 1.25M - 10.5M (9.25M)
Memory peak : 10.5M
Contador de seleções SQL: 20
Contador de execuções SQL: 7
Contador de requisições SQL: 27
Data:6.6E-5 SQL: SET NAMES utf8
Data:3.4E-5 SQL: SET CHARACTER SET utf8
Data:8.2E-5 SQL: SELECT * FROM nodes WHERE nodetype=1 ORDER BY nodeid
Data:0.000334 SQL: SELECT u.*,s.* FROM sessions s,users u WHERE s.sessionid='255fdcc3ec0f7ba55be7180cf55371e0' AND s.status=0 AND s.userid=u.userid AND ((s.lastaccess+u.autologout>1295894614) OR (u.autologout=0)) AND ((u.userid BETWEEN 000000000000000 AND 099999999999999))
Data:4.5E-5 SQL: SELECT MAX(g.gui_access) as gui_access FROM usrgrp g, users_groups ug WHERE ug.userid=1 AND g.usrgrpid=ug.usrgrpid
Data:4.7E-5 SQL: SELECT g.usrgrpid FROM usrgrp g, users_groups ug WHERE ug.userid = 1 AND g.usrgrpid = ug.usrgrpid AND g.users_status = 1 LIMIT 1 OFFSET 0
Data:0.002111 SQL: UPDATE sessions SET lastaccess=1295894614 WHERE sessionid='255fdcc3ec0f7ba55be7180cf55371e0'
Data:5.9E-5 SQL: SELECT g.usrgrpid FROM usrgrp g, users_groups ug WHERE ug.userid = 1 AND g.usrgrpid = ug.usrgrpid AND g.debug_mode = 1 LIMIT 1 OFFSET 0
Data:9.2E-5 SQL: SELECT * FROM profiles WHERE userid=1 AND ((profileid BETWEEN 000000000000000 AND 099999999999999)) ORDER BY userid ASC, profileid ASC
Data:6.1E-5 SQL: SELECT * FROM config WHERE ((configid BETWEEN 000000000000000 AND 099999999999999))
Data:5.7E-5 SQL: SELECT title1, url1, title2, url2, title3, url3, title4, url4, title5, url5 FROM user_history WHERE userid=1
Data:4.2E-5 SQL: begin
Data:7.6E-5 SQL: SELECT h.hostid FROM hosts h WHERE ((h.hostid BETWEEN 000000000000000 AND 099999999999999)) AND h.status IN (0,1) AND ( (h.host IN ('Zabbix server')) ) LIMIT 1 OFFSET 0
Data:4.1E-5 SQL: SELECT h.hostid FROM hosts h WHERE ((h.hostid BETWEEN 000000000000000 AND 099999999999999)) AND h.status IN (5,6) AND (h.hostid IN (0))
Data:0.000309 SQL: SELECT g.groupid FROM groups g WHERE ((g.groupid BETWEEN 000000000000000 AND 099999999999999)) AND ( (g.name IN ('Zabbix servers')) ) LIMIT 1 OFFSET 0
Data:0.000154 SQL: SELECT g.* FROM groups g WHERE ((g.groupid BETWEEN 000000000000000 AND 099999999999999)) AND ( (g.name IN ('Zabbix servers')) )
Data:0.00015 SQL: SELECT g.groupid FROM groups g WHERE ((g.groupid BETWEEN 000000000000000 AND 099999999999999)) AND ( (g.name IN ('CIMAR')) ) LIMIT 1 OFFSET 0
Data:4.7E-5 SQL: SELECT g.groupid FROM groups g WHERE ((g.groupid BETWEEN 000000000000000 AND 099999999999999)) AND ( (g.name IN ('CIMAR')) ) LIMIT 1 OFFSET 0
Data:0.000102 SQL: SELECT nextid FROM ids WHERE nodeid=0 AND table_name='groups' AND field_name='groupid' FOR UPDATE
Data:0.000106 SQL: SELECT max(groupid) AS id FROM groups WHERE groupid>=0 AND groupid<=99999999999
Data:0.000119 SQL: INSERT INTO ids (nodeid,table_name,field_name,nextid) VALUES (0,'groups','groupid',6)
Data:0.00011 SQL: INSERT INTO groups (name,groupid) VALUES ('CIMAR',6)
Data:9.5E-5 SQL: SELECT g.* FROM groups g WHERE ((g.groupid BETWEEN 000000000000000 AND 099999999999999)) AND (g.groupid IN (6))
Data:6.8E-5 SQL: SELECT h.* FROM hosts h WHERE ((h.hostid BETWEEN 000000000000000 AND 099999999999999)) AND h.status=3 AND ((h.hostid BETWEEN 000000000000000 AND 099999999999999)) AND ( (h.host IN ('001_Apache')) )
Data:0.000218 SQL: rollback
Data:0.000307 SQL: SELECT DISTINCT g.* FROM groups g,hosts_groups hg,hosts h WHERE ((g.groupid BETWEEN 000000000000000 AND 099999999999999)) AND hg.groupid=g.groupid AND h.hostid=hg.hostid AND h.status IN(0,1)
Data:4.7E-5 SQL: SELECT title5, url5 FROM user_history WHERE userid=1
Tempo total gasto na SQL: 0.004979
******************** Fim de script ***************************
Export is ok.
Best Regards,
Adail Horst
Debug Info:
Memory peak : 10.5M
