Fatal error: Call to undefined function sprint_f()
  • bixuan
    • Jan 2011
    I use Centos5.4 64bit and Zabbix-1.8.4
    When I create the graph from "templates", then show me this message:
    Fatal error: Call to undefined function sprint_f() in /opt/wwwroot/zabbix/api/classes/class.cgraph.php on line 901
    How can I do it?
    thanks a lot.
  • awshima
    • Nov 2008
    Same error here, while adding a graph:
    PHP Fatal error: Call to undefined function sprint_f() in /usr/local/share/zabbix/api/classes/class.cgraph.php on line 901
    In my case, it looks like it can't print a error message: S_GRAPH_ALREADY_EXISTS_ON
    • richlv
      • Oct 2005
      • 3112
      hmm. looks like this problem should be already fixed in the latest 1.8 development versions (and should work ok in 1.8.5).
      the problem most likely is encountered when attempting to create a graph with a name that already exists, so to avoid it you can use a unique name
