hi,
i´m using zabbix server and agent 1.8.4.
if i only unlink a template, the item is always on the host. i know this is, that you can have a look on the historical data, but my problem is, that the item continuing data collect. the item is always active. is it a bug?
i think the "shadow item" should be disabled after i unlink the template.
i don´t want to unlink and clear, because than i could not look onto the historical data.
does anyone have a solution for this?
br zychonatic
br zychonatic
