Sum 2 graphs
  • nima0102
    • May 2010
    • 106
    Sum 2 graphs
    Hi
    Absolutely many of administrators worked with "cacti". in Cacti we can "sum" 2 or more graphs in one display.for example you can sum graph1 and graph2 on one display.
    The only way I found to do this in zabbix is ,first create one new item as type calculated for item_1 and item_2.and then create graph for that new item!
    According to reported problem in " https://support.zabbix.com/browse/ZBXNEXT-615 " topic this way is not very good for creating sum graph.
    So the better way is sum graphs as same as cacti does.
    Can I sum graph as same as cacti??
    Thanks in advance
  • nima0102
    • May 2010
    • 106
    Hi
    Is there any suggestion for this topic?
    Thanks in advance
    • untergeek
      • Jun 2009
      • 512
      Zabbix doesn't do this, unfortunately. At least, not in the way that Cacti does.
      Zabbix does do aggregate items (you'd create a new item which was the sum of 2 or more other items) and you could graph that.
      Also, creating a calculated item would allow for this too, then graph that item.
      Stacked graphs are your third option, which would allow you to color-code and see what each member of the graph was doing individually.
      • nima0102
        • May 2010
        • 106
        Hi
        I have created https://support.zabbix.com/browse/ZBXNEXT-666 feature request in support zabbix. If anyone see this feature is useful please vote this.
        Thanks in advance
