I'm running 1.8.4 server on RHEL.
snmpget running every second pulls every value without fail.
When I put the same OIDs into Zabbix, I get some timeouts and even a few Disabling/Enabling SNMP Host messages, but the data is coming, however sporadically.
Host0 has no dropouts and always connects and works.
Host1 has a few dropouts.
Host2 has the most dropouts and almost never connects and works.
Host3 has many dropouts.
These servers are NOT loaded down. They are ENORMOUS Solaris servers with dozens of CPU cores.
I am running 3 checks on each host with a 120 second interval for each check (12 checks, at most, running simultaneously).
I increased my StartPollers from 25 to 50. This did not prevent timeouts.
I don't know what to make of this. This doesn't seem like it should be possible. I reiterate that snmpget hits these and gets the values correctly every time, run from my zabbix server. Why does Zabbix fail?
7549:20110209:131906.385 Item [host1.example.com:snmp[cpu-idle]] error: Timeout while connecting to [10.95.0.80:161]
7549:20110209:131906.395 SNMP Host [host1.example.com]: another network error, wait for 15 seconds
7555:20110209:131926.346 Item [host3.example.com:snmp[cpu-sys]] error: Timeout while connecting to [10.95.0.71:161]
7555:20110209:131934.919 SNMP Host [host3.example.com]: another network error, wait for 15 seconds
7567:20110209:131940.964 Item [host2.example.com:snmp[cpu-idle]] error: Timeout while connecting to [10.95.0.67:161]
7568:20110209:132052.773 Item [host2.example.com:snmp[cpu-user]] error: Timeout while connecting to [10.95.0.67:161]
7491:20110209:132057.137 Item [host3.example.com:snmp[cpu-sys]] error: Timeout while connecting to [10.95.0.71:161]
7491:20110209:132057.146 SNMP Host [host3.example.com]: first network error, wait for 15 seconds
7537:20110209:132059.192 Item [host1.example.com:snmp[cpu-sys]] error: Timeout while connecting to [10.95.0.80:161]
