Creating images via ZabbixAPI
  • mserg
    • Feb 2011
    PHP Code:
    require_once("ZabbixAPI.class.php");
    $img_filename='/usr/local/share/zabbix/map-images/cell.png';
    $img_file=fopen($img_filename, 'rb');
    $img_data=fread($img_file, filesize($img_filename));
    $img_create = ZabbixAPI::query('image','create',array('name'=>'myImage', 'image'=>base64_encode($img_data),'imagetype'=>2));
    fclose($img_file);
    write base64-coded blob field into table "image" mysql-db Zabbix (1.8.3), but after adding image via zabbix-frontend in blob-field by written decoded binary.
    Zabbix-frontend not read data from encoded blob.
    It's compatibility issue?
    How can I write unencoded binary via ZabbixAPI::query()?
  • mserg
    • Feb 2011
    fixed
    ${zabbix-www}/api/classes/class.cimage.php (323):
    add decoding before writing to the database:
    PHP Code:
    $ image['image'] = base64_decode($image['image']);
    • mserg
      • Feb 2011
      fixed in 1.8.4 =\
      • ribbon
        • Feb 2011
        The most problems that occur with the zabbix is with the server 1.8.3. And most of the problems are related with it. I think that your problem was gone as a result of the upgrade. Anyway I would recommend to update it so that most problems that will be solved as a result of it.
