clock of zabbix !!
  • nightwish
    • Dec 2010
    • 25
    clock of zabbix !!
    Hi All
    I have zabbix server version 1.8.4 on a centOS 5.5
    I have mysqldatabase 5.1.54 on a different server with centOS 5.5
    I have more than 200 hosts and 6000 itens.
    I have this strange problem, for a item that is suppose tu run every 5 min. From times to times the values are duplicated this happen randomly:
    2011.Feb.14 10:03:13 66.044
    2011.Feb.14 09:58:13 98.1459
    2011.Feb.14 09:53:12 97.4643
    2011.Feb.14 09:48:14 97.4559
    2011.Feb.14 09:43:12 96.6638
    2011.Feb.14 09:38:11 97.3865
    2011.Feb.14 09:33:16 97.8835
    2011.Feb.14 09:28:14 98.6565
    2011.Feb.14 09:23:12 93.0764
    2011.Feb.14 09:18:11 97.4817
    2011.Feb.14 09:13:23 97.4834
    2011.Feb.14 09:13:13 97.6186
    2011.Feb.14 09:08:12 97.4996
    2011.Feb.14 09:08:10 97.3644
    2011.Feb.14 09:03:10 95.7773
    2011.Feb.14 08:58:14 97.8316
    2011.Feb.14 08:53:17 97.6247
    2011.Feb.14 08:48:17 98.4386
    2011.Feb.14 08:43:12 96.484
    2011.Feb.14 08:38:17 98.3356
    2011.Feb.14 08:33:12 98.0956
    2011.Feb.14 08:28:21 97.774
    2011.Feb.14 08:23:20 96.103
    2011.Feb.14 08:18:15 97.6617
    2011.Feb.14 08:13:20 70.4592
    2011.Feb.14 08:08:10 97.9776
    2011.Feb.14 08:03:14 96.9961
    2011.Feb.14 07:58:16 95.4538
    2011.Feb.14 07:53:19 98.0163
    2011.Feb.14 07:48:14 97.6167
    2011.Feb.14 07:43:14 96.6745
    2011.Feb.14 07:38:15 98.1639
    2011.Feb.14 07:33:23 97.7974
    2011.Feb.14 07:33:19 97.9135
    2011.Feb.14 07:28:11 98.2447
    2011.Feb.14 07:23:30 96.8665
    2011.Feb.14 07:23:16 95.3399
    2011.Feb.14 07:18:18 97.8773
    2011.Feb.14 07:18:13 97.7451
    2011.Feb.14 07:13:15 98.194
    2011.Feb.14 07:13:11 98.2779
    This appens for all my itens. Any one have any idea what possible could be the problem.
    Tahnks in advance
  • nightwish
    • Dec 2010
    • 25
    Anyone can point some directions !! ??
    Thanks in advance.
    Regards...
    • ribbon
      • Feb 2011
      I think you should look into the manual. It helped me a lot when I started with it. It has a very useful one, and most problems and FAQ are mentioned in it and the solution are very elaborated and precise. It helped me got over some of them and I hope that it will help you on that.
      • fmrapid
        • Aug 2010
        • 43
        This issue has been fixed in pre1.8.5.
