Zabbix SSH2 issues
  • Davidus
    • Dec 2010
    • 281
    Zabbix SSH2 issues
    Hello everyone
    I have RHEL 5.5 and using it on ppc64. Have already installed required applications and libraries and everything looks fine, accept SSH2 support.
    Have tried to fix following issue in different ways… For instance, I installed libssh2-1.2.7-1.el5.rf.ppc.rpm and libssh2-devel-1.2.7-1.el5.rf.ppc.rpm also compiled libssh2 using source code.
    Keep getting error on ./configure
    checking for SSH2 support... no
    configure: error: SSH2 library not found
    basically I`m using --with-ssh2 flag, however, have tried different once as well when compiled from source.
    Can anybody tell me what I`m doing wrong or what can I do to configure with ssh2 support zabbix 1.8.4
    Thank you in advance!!!
  • Firm
    • Dec 2009
    • 342
    Show contents of config.log file (numbers may vary) starting from
    configure:13088: checking for SSH2 support
    to
    configure:13248: error: SSH2 library not found
    • richlv
      • Oct 2005
      • 3112
      also, make sure you either install libssh2 in some systemwide location or specify path to it in the configure call
      • josea.munoz
        • Apr 2008
        Not working in my environment
        I'm running:
        ./configure --enable-server --enable-proxy --enable-agent --enable-ipv6 --with-mysql --with-jabber --with-libcurl -with-net-snmp --with-ssh2=/usr/include/libssh --with-openipmi --with-ldap
        or
        ./configure --enable-server --enable-proxy --enable-agent --enable-ipv6 --with-mysql --with-jabber --with-libcurl -with-net-snmp --with-ssh2 --with-openipmi --with-ldap
        Libssh is installed:
        libssh: /usr/include/libssh
        And always get
        What I'm doing wrong for SSH?
        • josea.munoz
          • Apr 2008
          Solved
          OK.
          This is solved. For RHEL download http://pkgs.repoforge.org/libssh2/ packages and after installing them, run:
