SNMP - value has unknown type [0x80]
  • kayjay
    • Jun 2010
    • 43
    I'm using V1.8.2 server and get lots of data via SNMP in most cases I juen use the raw numeric OID. In this case I am attempting to get the CPU loading of a switch. The server log shows this:-
    error: OID [1.3.6.1.4.1.890.1.5.8.16.9.7.0] value has unknown type [0x80]
    Yet "snmpget 10.104.102.2 -c public -v2c 1.3.6.1.4.1.890.1.5.8.16.9.7.0" correctly reports this:-
    SNMPv2-SMI::enterprises.890.1.5.8.16.9.7.0 = INTEGER: 44
    What can the problem be?
    Many Thanks
  • untergeek
    • Jun 2009
    • 512
    Did you try putting in a leading . in front of the OID?
    If you have the MIBs installed at zabbix_server start time, you can also use the MIB name, e.g.
    .1.3.6.1.4.1.890.1.5.8.16.9.7.0
    or
    • kayjay
      • Jun 2010
      • 43
      In general I find it simpler to locate the correct OID using my mib browser tools and then use the value for OID that it gives me directly - that way I don't have to install any mibs and I already have 'proved' that it's correct. The fact that snmpget works OK is what puzzles me. I don't have a leading '.' in any of my other similar 'items' and they all work great.
      • pHiney
        • Sep 2011
        • 16
        SameSame
        This is precisely what i have.
        are there debug logs, debug levels ? anything that can be activated for just a host even ?
        I see that no one has responded, did it get resolved ?
        snmpwalk -v1 -c xxxxx  server1 .1.3.6.1.4.1.334.72.1.1.6.3.6
        SNMPv2-SMI::enterprises.334.72.1.1.6.3.6.0 = INTEGER: 134
        it's the lotus notes number of users.
        On the same device, i have the Network traffic in/out working. so i know snmp and zabbix is working.
        p
        • kayjay
          • Jun 2010
          • 43
          I am afraid not
          • pHiney
            • Sep 2011
            • 16
            oh sod.
            look carefully at the example i gave.
            there's an extra '.0' in the answer.
            as soon as i added the extra .0, it worked
            i really dislike the silliness of SNMP
            p
            • shalley303
              • Mar 2012
              I was getting this error on a standard INTEGER type OID. I eventually noticed that I forgot to update the community string when I created the new item, so it was trying to use public. Pointing this out because it may be the cause of this error for others tracking down this thread.
