Zabbix Web monitor issue 1.8.4
  • stevenfoo
    • Mar 2008
    • 46
    I have just upgrade from 1.8.2 to 1.8.4 and notice the following
    I have 2 host with web monitored setup
    Host A
    1) monitor http://xyx.abc.com/test.asp with required (work fine)
    2) monitor http://xyx.abc.com/default.htm with required - works in 1.8.2 does not work anymore if keep return value 1 whereas the download/response data works fine.
    Host B
    1) similar to Host A 2) http://ctx.abc.com without required works in 1.8.2 but does not work anymore in 1.8.4.
    I tried to recreate Host A 2) ane Host B 1) also it does not work.
    Anyone could help?
  • stevenfoo
    • Mar 2008
    • 46
    Anyone from Zabbix could help?
    This is very frustrating.
    • stevenfoo
      • Mar 2008
      • 46
      All,
      I have recreated a new scenario as following
      Authentication: None
      Update Interval: 60 secs
      Agent: Internet Explorer 6.0
      Steps:
      URL: http://abc.com/about.htm
      Timeout: 15 secs
      Status code: 200,201
      Requried: Blank
      I still get the error
      Failed on "Web Monitor" [1 of 1] Error: Status code did not match
      Reponse Time: 0s 2ms
      Reponse Code: 405
      Status: Fail - Error: Status code did not match
      I have another monitor to asp page and this works fine.
      Update Interval: 120 secs
      Steps:
      Name: Site ABC monitor
      URL: http://abc.com/search.asp
      Timeout: 15 secs
      Status code: 200,210
      Post: {product}=sste
      Requried: Blank
      Hope anyone there could help.
      • fmrapid
        • Aug 2010
        • 43
        Open in a ticket in the support interface. (You do not need to have paid support to open a ticket) Specify the version and that this is critical as it breaks functionality.
        Search support.zabbix.com prior to opening the ticket.
        Cheers,
        • mbradshaw93
          • Sep 2008
          I'm having a similar issue in Zabbix 1.8.4. We've been on this version for awhile. The monitor was working until this morning, when it started failing. I can do a wget on the URL that it is checking from our zabbix server and see what should (and has until now) matched the content check, but Zabbix still reports this failed.
          I added a new monitor, with the same URL and status code/required settings as the old, and it fails in the same way.
          Were you able to get this issue resolved?
          Thanks,
          Michael
          • sorin
            • Feb 2014
            • 11
            I opened a bug regarding the missing returned code and the checked URL, feel free to vote / comment on it https://support.zabbix.com/browse/ZBX-8134
