I was using 1.8.1. at first. In this version, I could edit a screen, click to edit a cell, select "graph" as the cell type, and then select a template item from a templated host and group, so the graph was *not* associated with a specific host. If marked as "Dynamic item", I could then view the screen, select a host that had that graph, and the host's data would be shown in the graph.
Now, in version 1.8.4, it is suddenly no longer possible to select templated groups or hosts, limiting the choices to graphs that are tied to a specific host, effectively eliminating the entire "dynamic item" feature.
I can hardly believe this was intentional, as it is clearly crippling to usage, but I have a hard time finding out why it works this way.
Can someone confirm this is a bug or explain me how things are supposed to work...?
Thank you very much.
