Trigger showing ZBX_NOTSUPPORTED
  • supratik
    • Feb 2011
    Hi
    I am trying to monitor a log file using Zabbix 1.8.4.
    I created an item using the following details:
    Host: Zabbix server
    Description: logger_test
    Type: Zabbix agent (active)
    Key: log[/tmp/scribetest/test3/test3_current,error,,100]
    Type of Infromation: Log
    Update interval (in sec): 1 sec
    Keep history (in days): 90
    Status: Active
    Applications: Log files
    I created a trigger and attached it with the item logger_test using the following details.
    Expression: {Zabbix server:log[/tmp/scribetest/test3/test3_current,error,,100].str(error)}=1
    Severity: disaster
    The above settings works fine for the first time but next time the trigger shows ZBX_NOTSUPPORTED and after that item also shows "not supported" message.
    Can you please tell me if anything I am doing wrong here ?
