Hi There,
I'm trying out Zabbix for the first time and have run into some problems. Hoping someone can help me out.
My setup is as follows:
* OpenBSD 3.8
* PostgreSQL 8.0.3
* PHP 4.4.1
* Zabbix 1.0
I ran into a couple of problems
1. make would fail due to it not being able to find the Postgres library+header files. configure wouldn't use the CPPFLAGS/LDFLAGS environment variable to add the correct directories. I solved this by editing the configure file by hand
There must be a cleaner way to do this...
2. PHP parser complained: [error] PHP Warning: Call-time pass-by-reference has been deprecated - argument passed by value; - I fixed this by setting the allow_call_time_pass_reference variable in php.ini. The web interface is now working.
3. I'm now struggling with the following error in zabbix_suckerd:
018766:20060126:155451 Starting zabbix_suckerd...
018766:20060126:155451 zabbix_suckerd #0 started [Housekeeper]
021451:20060126:155451 zabbix_suckerd #2 started [nodata() calculator]
009979:20060126:155452 zabbix_suckerd #1 started [Alerter]
026045:20060126:155452 zabbix_suckerd #3 started [ICMP pinger]
004940:20060126:155452 zabbix_suckerd #4 started [Sucker. SNMP:ON]
009979:20060126:155452 Query::select a.alertid,a.mediatypeid,a.sendto,a.subject,a.messa ge,a.status,a.retries,mt.mediatypeid,mt.type,mt.de scription,mt.smtp_server,mt.smtp_helo,mt.smtp_emai l,mt.exec_path from alerts a,media_type mt where a.status=0 and a.retries<3 and a.mediatypeid=mt.mediatypeid order by a.clock
009979:20060126:155452 Query failed:PGRES_FATAL_ERROR
018766:20060126:155452 One child process died. Exiting ...
018766:20060126:155452 Cannot kill process. PID=[9979] [No such process]
021451:20060126:155452 Got QUIT or INT or TERM or PIPE signal. Exiting...
026045:20060126:155452 Got QUIT or INT or TERM or PIPE signal. Exiting...
004940:20060126:155452 Got QUIT or INT or TERM or PIPE signal. Exiting...
The Postgres log shows the following:
LOG: could not send data to client: Broken pipe
LOG: unexpected EOF on client connection
The first few times I tried to start suckerd, I got these errors. It finally started and ran for a few hours, and it's now back to not starting at all. Any ideas on how to proceed troubleshooting this would be appreciated.
thanks,
-Stephen
* OpenBSD 3.8
* PostgreSQL 8.0.3
* PHP 4.4.1
* Zabbix 1.0
There must be a cleaner way to do this...2. PHP parser complained: [error] PHP Warning: Call-time pass-by-reference has been deprecated - argument passed by value; - I fixed this by setting the allow_call_time_pass_reference variable in php.ini. The web interface is now working.
thanks,
-Stephen
