I actually have two problems with my Zabbix :
1) when I set a discovery rule,, normally the "delay" parameter sets frequency of executing this rule (in seconds), but whatever value I put for this parameter, the rule is executed every 12 minutes and this doesn't change no matter what I change in the configuration. Is it a kknown bug? does any one have a solution for this
2) timestamp for all data in the web frontend is displayed wrong, it is always shifted +2 hours (in events, data, graphs...)
but i'm quite sure that it is correctly saved in DB (when I use macro {EVENT.TIME} for example in mail notifications, i receive the correct value of time) so please if there's any trick for this, i'm waiting for your help
thank you
thank you
