Hello all,
Installed the 1.8.4 version on the following server using the instructions from the manual:
SUSE Linux Enterprise Server 10 (x86_64)
VERSION = 9
PATCHLEVEL = 2
LSB_VERSION="core-2.0-noarch:core-3.0-noarch:core-2.0-x86_64:core-3.0-x86_64"
Using remote DB2 V9.7 as the database backend. When firing up the the zabbix_server, the process fails and the zabbix_server.log contains messages regarding out of memory
4059:20110309:023717.672 Starting Zabbix Server. Zabbix 1.8.4 (revision 16604).
4059:20110309:023717.672 ****** Enabled features ******
4059:20110309:023717.672 SNMP monitoring: NO
4059:20110309:023717.672 IPMI monitoring: NO
4059:20110309:023717.672 WEB monitoring: NO
4059:20110309:023717.672 Jabber notifications: NO
4059:20110309:023717.672 Ez Texting notifications: NO
4059:20110309:023717.672 ODBC: NO
4059:20110309:023717.672 SSH2 support: NO
4059:20110309:023717.672 IPv6 support: NO
4059:20110309:023717.672 ******************************
4059:20110309:023717.789 [file:db.c,line:885] zbx_malloc: out of memory. Requested 47888885350412 bytes.
Didn't enable alot of features initially as you can see from the output. Was planning on invoking zabbix_sender to cram metrics into the system at first.
Anyway, any direction towards a resolution that anyone can provide would be most appreciated.
Trey
VERSION = 9
PATCHLEVEL = 2
Trey
