triger for monitoring log files
  • mario.almeida
    • Nov 2008
    • 44
    Hi All,
    I am using zabbix 1.8.4
    I tried the below 2 trigers but non seems to be working.
    {server:log[/tmp/zabbix.log,signature check failed].str(signature check failed)}=1
    {server:log[/tmp/zabbix.log,signature check failed].nodata(0)}#1
    For the first time the triger will come true but it never become false.
    Noticed under latest data -> history also it is not updated.
  • mario.almeida
    • Nov 2008
    • 44
    Hi All,
    After analysing found that data under history is update but the trigger is not turned off
    Can someone help me in this.
    • mario.almeida
      • Nov 2008
      • 44
      Seems like no one has faced this kind issue.
      • mario.almeida
        • Nov 2008
        • 44
        Any hints to find the cause.
        • vinh.ho
          • Nov 2010
          • 10
          sorry but is it important to monitor zabbix log ?
          because when you create new trigger or item, if your configuration not true, when you restart zabbix_agentd, the zabbib_agentd.log show immediately
          and the fact is you are sometine restart your zabbix_agentd
          so is it important & you're monitoring zabbix log file for what ?
          • mario.almeida
            • Nov 2008
            • 44
            Well, Just because I put /tmp/zabbix.log it dose not mean I am monitoring zabbix log files.
            BTW, even if I am monitoring zabbix log the functionality should work for what it is meant.
            Please note: /tmp/zabbix.log file is an example.
            • vinh.ho
              • Nov 2010
              • 10
              ok bro
              i know some application that can share with you
              if you want to analyze apache log, take a look to Awstats
              Awstats is an application that analyze your access_log and build it to a web,
              then you must create items & trigger to monitor some feature of it
              have fun man !
              • mario.almeida
                • Nov 2008
                • 44
                Thanks for the alternative,
                But thats not what I am looking for.
                By having another application to monitor the log files meaning using more resources on the client side.
                My point is to find a solution for zabbix rather to go for an alternative.
                As an alternative, I still use zabbix to monitor the log files, but in cron job I execute a SQL query to set the value of that trigger to 0.
                I will stick to this as an alternative then to install another application on all the clients.
                I did use watchlog but prefer to stick with zabbix its easy for me.
