How to press a button in a Web Monitoring?
  • dickinson
    • Oct 2010
    • 44
    Hi, i've googled for this but I havent found help. What I need is to know how I can press a button in one step in Web Monitoring. The explanation: the app I need to monitor has three bottons and one text box. My step consists in put some text and press an specific button. The "enter" doesn't work.
    I'm sure that this question may be useful to many people.
    Thanks from colombia
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    It really depends what happens when you press the Enter button. If it just go to a different URL with a number of GET or POST variables then you can monitor it by Zabbix, no problem.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • dickinson
      • Oct 2010
      • 44
      The page simply perform a test of the response of a web service. I atach an image of the page, may be it helps.
      My question would be how can "press" the second button (see image) using post method, or something like this?
      Note: When you access the page, the focus is in any button.
      • dickinson
        • Oct 2010
        • 44
        Please any idea? I also tried using the "id" of each control, I saw the source code of the html page, but the time zabbix reports is not real.
        I know you can help me
        • khiri
          • Feb 2005
          What is the URL after you click the button? Can you just monitor that?
          • dickinson
            • Oct 2010
            • 44
            guess I Solved
            After reading too much about curl and html POST method, i used wireshark to identify what my browser exactly sends in POST. Then I used a firefox addon called Tamper Data to collect the data and see clearly the post variables. And BINGO!.. A variable that the app uses was missing. I added in the POST box of the step and seems to work. I'm doing final checks..but i thing I see the light at the end of the tunnel..
