Action not working
  • mario.almeida
    • Nov 2008
    • 44
    Action not working
    Dear All,
    Action for the following trigger is not work. It works for CPU usage and otehrs
    Trigger:
    {Template-app-02:log["/usr/isa/aares/logs-02/paymentbroker.log","SSLHandshakeException"].str(SSLHandshakeException)}=1
    Template-app-02 is add for host app71
    And below is the Action
    Name
    Paymentbroker: SSL Handshake Error
    Conditions
    Trigger = "app71:Zabbix Alert: Paymentbroker SSLHandshake Exception on {HOSTNAME}"
    Operations
    Send message to Group "Zabbix administrators"
    Status
    Enabled
    Under Latest data for host app71
    [2011.Mar.24 06:02:09] - - Unknown - Thu Mar 24 06:01:51 GMT 2011 This line added by Remy for testing SSLHandshakeException
    for Severity it says Unknown
    Under Events
    24 Mar 2011 06:02:09 Zabbix Alert: Paymentbroker SSLHandshake Exception on app71 PROBLEM High 7m 1s No -
    For Actions it says '-'
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Not sure what kind of problem you have here (check user medias, user permissions for a start), but you should have condition Trigger value = Problem to make it work properly, especially if you use escalations.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • mario.almeida
      • Nov 2008
      • 44
      Hi Alexei,
      Its the Zabbix administrator group and users is Admin,
      The same user gets notifications for other triggers.
      BTW, I did not understand how Trigger value = Problem will work. You mean in addition to the existing trigger add this one also?
      And what does Unknown for Severity means, May be coz of this its not working.
