ORA-24806: LOB form mismatch
  • BDiE8VNy
    • Apr 2010
    • 680
    showing the history of an item with values of type 'Text' fails with an error message:
    OCI-Lob::load() [<a href='function.OCI-Lob-load'>function.OCI-Lob-load</a>]: ORA-24806: LOB form mismatch[/usr/share/zabbix/include/db.inc.php:626]
    for each line / value in the history.
    The item's value is taken by a Shell-Command:
    UserParameter=openvz.updateubc,/usr/bin/sudo /usr/bin/install -o zabbix -g zabbix -m 440 /proc/user_beancounters /var/log/zabbix/user_beancounters && echo Update succeeded || echo Update failed
    In the view of 'Latest data' the column 'Last value' shows the value as expected ('Update succeeded').
    I found a closed PHP bug (http://bugs.php.net/35973) which produces the same error message but I'm not sure if the mentioned issue is the same.
    Any ideas?
    System environment
    Server: ZABBIX 1.8.4 (Oracle Call Interface)
    Proxy: ZABBIX 1.8.4 (sqlite3)
    Agents: ZABBIX 1.8.4 (connection via proxies and directly)
    Server Database: Oracle RDBMS 11.2.0.1
    OS: CentOS release 5.5
    PHP: 5.1.6-27.el5_5.3
    PHP OCI8-Module: 5.1.6-27.el5_5.3 with oracle-instantclient11.2-basic-11.2.0.2.0-1
  • BDiE8VNy
    • Apr 2010
    • 680
    I think the mentioned PHP bug is not responsible for this issue.
    Our DBA has changed the datatype of the column 'value' in the table 'history_text' from 'NCLOB' to 'CLOB'.
    The issue still exists.
    -- rename existing NCLOB column
    ALTER TABLE history_text RENAME COLUMN value TO value_nclob;
    -- add new CLOB column
    ALTER TABLE history_text ADD value CLOB DEFAULT '';
    -- copy existing NCLOB values into new CLOB column
    UPDATE history_text SET value = value_nclob;
    COMMIT;
    • BDiE8VNy
      • Apr 2010
      • 680
