Bug in function evaluate_COUNT()
  • BDiE8VNy
    • Apr 2010
    • 680
    there is a (presumable Oracle dependent) bug in a SQL query:
    # sed -n 380,385p zabbix-1.8.4/src/libs/zbxserver/evalfunc.c
    		offset = zbx_snprintf(sql, sizeof(sql),
    				"select [B]count(value)[/B]"
    				" from %s"
    				" where itemid=" ZBX_FS_UI64,
    				get_table_by_value_type(item->value_type),
    				item->itemid);
    Select queries with 'count(value)' won't work when column 'value' is of any kind of 'LOB' datatypes:
    select count(value) from history_text where itemid=26212 and clock<=1301417122 and clock>1301417122
    ORA-00932: inconsistent datatypes: expected - got NCLOB
  • Gomex
    • Apr 2009
    • 11
    Report bug
    It should be reported as bug:
    • BDiE8VNy
      • Apr 2010
      • 680
      • Gomex
        • Apr 2009
        • 11
        good job!
        Now, just wait some response
