I have problem with icmppingsec because on two servers it works and on the other servers it don't work.
My configuration item on the server A (work):
zabbix server and agent 1.8.4 / Redhat 5.6
The same configuration I put to another server, and doesn't work
My configuration item on the server B (work):
Ping is ok, but zabbix all the time show me a 0ms on the graph
Solved: icmpping is running from zabbix server. I would check ping between two different servers where I have zabbix_agent
Type: simple check Key: icmppingsec[10.0.10.10,5,300,128,100,avg] Type of information: float Units: ms Use custom multiplier: 1000 Update intervals: 30
rpm -qa |grep fping fping-2.2b1-1 ls -lh /usr/sbin/fping -rws--s--- 1 root zabbix 20K Feb 2 2001 /usr/sbin/fping
fping 10.0.10.10 -c5 -p300 -b128 -t100 10.0.10.10 : [0], 156 bytes, 0.74 ms (0.74 avg, 0% loss) 10.0.10.10 : [1], 156 bytes, 0.51 ms (0.62 avg, 0% loss) 10.0.10.10 : [2], 156 bytes, 0.59 ms (0.61 avg, 0% loss) 10.0.10.10 : [3], 156 bytes, 0.54 ms (0.59 avg, 0% loss) 10.0.10.10 : [4], 156 bytes, 0.57 ms (0.59 avg, 0% loss) 10.0.10.10 : xmt/rcv/%loss = 5/5/0%, min/avg/max = 0.51/0.59/0.7
Type: simple check Key: icmppingsec[10.7.224.100,5,300,128,100,avg] Type of information: float Units: ms Use custom multiplier: 1000 Update intervals: 30
fping 10.7.224.100 -c5 -p300 -b128 -t100 10.7.224.100 : [0], 156 bytes, 0.62 ms (0.62 avg, 0% loss) 10.7.224.100 : [1], 156 bytes, 0.52 ms (0.57 avg, 0% loss) 10.7.224.100 : [2], 156 bytes, 0.45 ms (0.53 avg, 0% loss) 10.7.224.100 : [3], 156 bytes, 0.31 ms (0.47 avg, 0% loss) 10.7.224.100 : [4], 156 bytes, 0.32 ms (0.44 avg, 0% loss) 10.7.224.100 : xmt/rcv/%loss = 5/5/0%, min/avg/max = 0.31/0.44/0.62
