Zabbix 1.1 release 5 - Not supported items
  • esisa
    • Aug 2005
    Hi!
    I am setting up Zabbix 1.1 release 5. I have set up the server with zabbix_suckerd and a client with zabbix_agentd. I get information about the processor load, but I can for example not get information about disk space. I use the templates provided to check for disk space but Zabbix configurations of items tells me it is not supported.
    Why is it not supported, and how can I get it to support it?
  • Hal
    • Jan 2006
    • 10
    Naming of the keys has been changed and your templates use already old naming.
    Read this: http://www.zabbix.com/manual/v1.1/config_items.php.
    In section Zabbix agent you can find new naming.
    Hal
    • esisa
      • Aug 2005
      Hal
      Ok, I was wondering if that was the problem, but I didn't get it right. I have to look further into this when I get back to work tomorrow.
      Thanks!
