Hey,
I was trying to properly set triggers up, there seem to be a few bugs.
First of all, when i try to modify an existing trigger using [Change] on the right of the screen, and then clicking the "Update" button from the "CONFIGURATION OF TRIGGERS" tab and "Trigger" table, that trigger just seems to disappear from the trigger list for that host, but the message "[Trigger updated]Updated trigger from linked host aquila" does appear at the top of the list page.
Also, i tried creating a trigger from scratch and it appeared doubled in the list
This appeared in the log file:
Whats wrong?
13775 Zabbix: Zabbix_server malfunction on aquila {aquila:proc.num[zabbix_server].last(0)}#11 Warning Enabled Change
13774 Zabbix: Zabbix_server malfunction on aquila {aquila:proc.num[zabbix_server].last(0)}#11 Warning Enabled Trigger just added. No status update so far. Change
2006.Feb.06 16:34:02
Expression [{12881}#11] cannot be evaluated [Unable to get value for functionid [12881]]
Evaluation of expression [{12881}#11] failed [Unable to get value for functionid [12881]]
Expression [{12880}#11] cannot be evaluated [Unable to get value for functionid [12880]]
Evaluation of expression [{12880}#11] failed [Unable to get value for functionid [12880]]
