I have recently set up an item for monitoring for memory.
The formula is:
last("vm.memory.size[total]")-last("vm.memory.size[available]")
The problem is when the agent was stopped (host was shut down), this item is still calculating from the last value from the last check, while the other items (vm.memory.size[total] and vm.memory.size[available]) were halted.
It seems that the calculated item used the last value for the calculation but not the latest value (which should be unavailable).
Is there a workaround on this?
Thanks.
The formula is:
Thanks.
