Ok. Here I Am Again... This time it seems that my problem is in mysql. The problem i have is that zabbix appears as "zabbix server is running - YES", but 3 seconds later it appears as "zabbix server is running - NO". This status of zabbix are real (i mean, when zabbix appears as not running, it really is "not running"). And here is my zabbix_server.log file:
My configuration files are ok... the username, password an host are also ok. So as you can see i don't have any idea of what i should do to make it work right. Thanks in advance... i hope someone could give a hint on what to do.
Thank you
2296:20110423:075840.833 Starting Zabbix Server. Zabbix 1.8.4 (revision 16604) . 2296:20110423:075840.833 ****** Enabled features ****** 2296:20110423:075840.833 SNMP monitoring: YES 2296:20110423:075840.833 IPMI monitoring: NO 2296:20110423:075840.833 WEB monitoring: YES 2296:20110423:075840.833 Jabber notifications: YES 2296:20110423:075840.834 Ez Texting notifications: YES 2296:20110423:075840.834 ODBC: NO 2296:20110423:075840.834 SSH2 support: NO 2296:20110423:075840.834 IPv6 support: NO 2296:20110423:075840.834 ****************************** 2296:20110423:075840.856 [Z3001] Connection to database 'zabbix' failed: [2002 ] Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.soc k' (2) 6466:20110424:063232.028 Starting Zabbix Server. Zabbix 1.8.4 (revision 16604) . 6466:20110424:063232.029 ****** Enabled features ****** 6466:20110424:063232.029 SNMP monitoring: YES 6466:20110424:063232.029 IPMI monitoring: NO 6466:20110424:063232.029 WEB monitoring: YES 6466:20110424:063232.029 Jabber notifications: YES 6466:20110424:063232.029 Ez Texting notifications: YES 6466:20110424:063232.029 ODBC: NO 6466:20110424:063232.029 SSH2 support: NO 6466:20110424:063232.029 IPv6 support: NO 6466:20110424:063232.029 ****************************** 6466:20110424:063232.032 [Z3001] Connection to database 'zabbix' failed: [2002 ] Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.soc k' (111) 6574:20110424:064817.244 Starting Zabbix Server. Zabbix 1.8.4 (revision 16604) . 6574:20110424:064817.245 ****** Enabled features ****** 6574:20110424:064817.245 SNMP monitoring: YES 6574:20110424:064817.245 IPMI monitoring: NO 6574:20110424:064817.245 WEB monitoring: YES 6574:20110424:064817.245 Jabber notifications: YES 6574:20110424:064817.245 Ez Texting notifications: YES 6574:20110424:064817.245 ODBC: NO 6574:20110424:064817.245 SSH2 support: NO 6574:20110424:064817.245 IPv6 support: NO 6574:20110424:064817.245 ****************************** 6574:20110424:064817.252 [Z3001] Connection to database 'zabbix' failed: [2002 ] Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.soc k' (111) 6758:20110424:064959.153 Starting Zabbix Server. Zabbix 1.8.4 (revision 16604) . 6758:20110424:064959.154 ****** Enabled features ****** 6758:20110424:064959.154 SNMP monitoring: YES 6758:20110424:064959.154 IPMI monitoring: NO 6758:20110424:064959.154 WEB monitoring: YES 6758:20110424:064959.154 Jabber notifications: YES 6758:20110424:064959.154 Ez Texting notifications: YES 6758:20110424:064959.154 ODBC: NO 6758:20110424:064959.154 SSH2 support: NO 6758:20110424:064959.154 IPv6 support: NO 6758:20110424:064959.154 ****************************** 6759:20110424:064959.346 server #1 started [DB Cache] 6773:20110424:064959.407 server #15 started [Housekeeper] 6773:20110424:064959.429 Executing housekeeper 6766:20110424:064959.442 server #8 started [Trapper] 6772:20110424:064959.428 server #14 started [Alerter] 6769:20110424:064959.451 server #11 started [Trapper] 6770:20110424:064959.488 server #12 started [Trapper] 6765:20110424:064959.497 server #7 started [Poller for unreachable hosts. SNMP :YES] 6767:20110424:064959.505 server #9 started [Trapper] 6771:20110424:064959.525 server #13 started [ICMP pinger] 6768:20110424:064959.548 server #10 started [Trapper] 6778:20110424:064959.566 server #16 started [Timer] 6779:20110424:064959.567 server #17 started [HTTP Poller] 6763:20110424:064959.582 server #5 started [Poller. SNMP:YES] 6782:20110424:064959.583 server #19 started [DB Syncer] 6785:20110424:064959.587 server #21 started [DB Syncer] 6786:20110424:064959.587 server #22 started [DB Syncer] 6787:20110424:064959.590 server #23 started [Escalator] 6758:20110424:064959.595 server #0 started [Watchdog] 6784:20110424:064959.613 server #20 started [DB Syncer] 6788:20110424:064959.615 server #24 started [Proxy Poller] 6764:20110424:064959.638 server #6 started [Poller. SNMP:YES] 6760:20110424:064959.642 server #2 started [Poller. SNMP:YES] 6761:20110424:064959.682 server #3 started [Poller. SNMP:YES] 6781:20110424:064959.747 server #18 started [Discoverer. SNMP:YES] 6762:20110424:064959.789 server #4 started [Poller. SNMP:YES] 6759:20110424:065001.216 __mem_malloc: skipped 0 asked 40 skip_min 4294967295 skip_max 0 6759:20110424:065001.217 [file:dbconfig.c,line:1221] zbx_mem_malloc(): out of memory (requested 36 bytes). 6759:20110424:065001.218 [file:dbconfig.c,line:1221] zbx_mem_malloc(): please increase CacheSize configuration parameter. 6758:20110424:065001.233 One child process died (PID:6759,exitcode/signal:255) . Exiting ... 6758:20110424:065003.257 Syncing history data... 6758:20110424:065003.341 Syncing history data... done. 6758:20110424:065003.341 Syncing trends data... 6758:20110424:065003.508 Syncing trends data... done. 6758:20110424:065003.508 Zabbix Server stopped. Zabbix 1.8.4 (revision 16604). 7440:20110424:070941.310 Starting Zabbix Server. Zabbix 1.8.4 (revision 16604) . 7440:20110424:070941.310 ****** Enabled features ****** 7440:20110424:070941.310 SNMP monitoring: YES 7440:20110424:070941.310 IPMI monitoring: NO 7440:20110424:070941.310 WEB monitoring: YES 7440:20110424:070941.310 Jabber notifications: YES 7440:20110424:070941.310 Ez Texting notifications: YES 7440:20110424:070941.310 ODBC: NO 7440:20110424:070941.310 SSH2 support: NO 7440:20110424:070941.310 IPv6 support: NO 7440:20110424:070941.310 ****************************** 7441:20110424:070941.532 server #1 started [DB Cache] 7449:20110424:070941.547 server #9 started [Trapper] 7450:20110424:070941.549 server #10 started [Trapper] 7451:20110424:070941.552 server #11 started [Trapper] 7452:20110424:070941.558 server #12 started [Trapper] 7453:20110424:070941.563 server #13 started [ICMP pinger] 7448:20110424:070941.603 server #8 started [Trapper] 7455:20110424:070941.606 server #14 started [Alerter] 7457:20110424:070941.608 server #15 started [Housekeeper] 7457:20110424:070941.608 Executing housekeeper 7459:20110424:070941.638 server #16 started [Timer] 7446:20110424:070941.643 server #6 started [Poller. SNMP:YES] 7462:20110424:070941.645 server #17 started [HTTP Poller] 7465:20110424:070941.667 server #19 started [DB Syncer] 7447:20110424:070941.678 server #7 started [Poller for unreachable hosts. SNMP :YES] 7443:20110424:070941.680 server #3 started [Poller. SNMP:YES] 7464:20110424:070941.717 server #18 started [Discoverer. SNMP:YES] 7442:20110424:070941.718 server #2 started [Poller. SNMP:YES] 7470:20110424:070941.719 server #20 started [DB Syncer] 7473:20110424:070941.722 server #21 started [DB Syncer] 7475:20110424:070941.725 server #22 started [DB Syncer] 7477:20110424:070941.732 server #23 started [Escalator] 7479:20110424:070941.735 server #24 started [Proxy Poller] 7440:20110424:070941.739 server #0 started [Watchdog] 7445:20110424:070941.745 server #5 started [Poller. SNMP:YES] 7444:20110424:070941.816 server #4 started [Poller. SNMP:YES] 7441:20110424:070943.153 __mem_malloc: skipped 0 asked 40 skip_min 4294967295 skip_max 0 7441:20110424:070943.153 [file:dbconfig.c,line:1221] zbx_mem_malloc(): out of memory (requested 36 bytes). 7441:20110424:070943.153 [file:dbconfig.c,line:1221] zbx_mem_malloc(): please increase CacheSize configuration parameter. 7440:20110424:070943.157 One child process died (PID:7441,exitcode/signal:255) . Exiting ... 7440:20110424:070945.181 Syncing history data... 7440:20110424:070945.209 Syncing history data... done. 7440:20110424:070945.210 Syncing trends data... 7440:20110424:070945.224 Syncing trends data... done. 7440:20110424:070945.225 Zabbix Server stopped. Zabbix 1.8.4 (revision 16604). 22659:20110424:091912.732 Starting Zabbix Server. Zabbix 1.8.4 (revision 16604) . 22659:20110424:091912.739 ****** Enabled features ****** 22659:20110424:091912.741 SNMP monitoring: YES 22659:20110424:091912.741 IPMI monitoring: NO 22659:20110424:091912.741 WEB monitoring: YES 22659:20110424:091912.741 Jabber notifications: YES 22659:20110424:091912.741 Ez Texting notifications: YES 22659:20110424:091912.741 ODBC: NO 22659:20110424:091912.741 SSH2 support: NO 22659:20110424:091912.742 IPv6 support: NO 22659:20110424:091912.742 ****************************** 22660:20110424:091912.978 server #1 started [DB Cache] 22667:20110424:091912.989 server #8 started [Trapper] 22668:20110424:091912.989 server #9 started [Trapper] 22675:20110424:091912.990 server #16 started [Timer] 22674:20110424:091912.991 server #15 started [Housekeeper] 22674:20110424:091912.991 Executing housekeeper 22672:20110424:091912.991 server #13 started [ICMP pinger] 22676:20110424:091912.991 server #17 started [HTTP Poller] 22673:20110424:091912.993 server #14 started [Alerter] 22671:20110424:091912.994 server #12 started [Trapper] 22670:20110424:091912.996 server #11 started [Trapper] 22681:20110424:091913.004 server #19 started [DB Syncer] 22685:20110424:091913.020 server #20 started [DB Syncer] 22686:20110424:091913.027 server #21 started [DB Syncer] 22669:20110424:091913.027 server #10 started [Trapper] 22687:20110424:091913.029 server #22 started [DB Syncer] 22688:20110424:091913.030 server #23 started [Escalator] 22689:20110424:091913.032 server #24 started [Proxy Poller] 22659:20110424:091913.034 server #0 started [Watchdog] 22677:20110424:091913.355 server #18 started [Discoverer. SNMP:YES] 22664:20110424:091913.356 server #5 started [Poller. SNMP:YES] 22665:20110424:091913.361 server #6 started [Poller. SNMP:YES] 22663:20110424:091913.366 server #4 started [Poller. SNMP:YES] 22661:20110424:091913.376 server #2 started [Poller. SNMP:YES] 22662:20110424:091913.403 server #3 started [Poller. SNMP:YES] 22666:20110424:091913.446 server #7 started [Poller for unreachable hosts. SNMP :YES] 22660:20110424:091914.583 __mem_malloc: skipped 0 asked 40 skip_min 4294967295 skip_max 0 22660:20110424:091914.583 [file:dbconfig.c,line:1221] zbx_mem_malloc(): out of memory (requested 36 bytes). 22660:20110424:091914.583 [file:dbconfig.c,line:1221] zbx_mem_malloc(): please increase CacheSize configuration parameter. 22659:20110424:091914.587 One child process died (PID:22660,exitcode/signal:255 ). Exiting ... 22659:20110424:091916.608 Syncing history data... 22659:20110424:091916.721 Syncing history data... done. 22659:20110424:091916.721 Syncing trends data... 22659:20110424:091916.908 Syncing trends data... done. 22659:20110424:091916.908 Zabbix Server stopped. Zabbix 1.8.4 (revision 16604).
Thank you
