problem zabbix agent
  • fabiomc
    • Nov 2009
    • 53
    hi
    in zabbix server 1.8.3 , i have the zabbix agent that works but i have problems with some trigger
    for this triggers, they say: "host is unavailable" but the zabbix agent is ok and i see it in HOSTS
    why ?
    1) Template_Linux:Zabbix_agentd is not running on {HOSTNAME} {zabbixroc.num[zabbix_agentd].last(0)}<1
    2) net.tcp.service[http]
    3) proc.num[zabbix_server]
  • italux
    • Jul 2010
    • 21
    First you need check your config file, are you sure the IP from your server is in this file?!
    Before this, try implement a trigger same this, to certify the agent response a request:
    agent.ping.nodata(60)
    More information in - http://www.zabbix.com/documentation/...config/items?s[]=agent&s[]=ping&s[]=nodata#zabbix_agent
