Zabbix from source on gentoo
  • luivm
    • May 2011
    im trying to install zabbix on (fcking) Gentoo system.
    When i run
    ./configure --enable-agent
    i recevice thi error :
    bash: ./configure: /bin/sh: bad interpreter: Permission denied
    Any idea ?
    Thank you to everyone
  • heaje
    • Sep 2009
    • 325
    Emerge on Gentoo
    You could just use the ebuild for Zabbix that is already in the Portage tree on Gentoo, then you wouldn't have to do the compile by yourself.
    To do that, just run "emerge zabbix". Make sure the use flags are set to whatever you want them to be so that you get the desired functionality. Version 1.8.4 is not masked for the amd64 and x86 architectures, so that will be what is installed. If you want version 1.8.5, you'll have to add zabbix to your portage.keywords file.
