problems with Items using SNMP
  • wikisb
    • May 2011
    • 64
    hi all!
    i wan't to monitor some interesting things of my hosts but i can't. one example of an item i can't work with it is this one: hrMemoryAvailable with OID: 1.3.6.1.4.1.2021.4.6. If i do a snmget against this item i get the following: Error in packet Reason noSuchName) there is no such variable name in this MIB. the same happens with hrSystemProcesses,... so getting this problem its normal my Zabbix can't monitor this items because it says is not supported.
    i have changed a couple of things in my snmp.conf but i can't manage to sort things out. i also added items like sysUpTime, sysName and they work with SNMP agent.
    any suggestion¿?
    thanks!!
  • MrKen
    • Oct 2008
    • 652
    Add a zero to the end of the oid,
    1.3.6.1.4.1.2021.4.6.0
    That should work.
    MrKen
    • wikisb
      • May 2011
      • 64
      MrKen thanks!!
      but not always it works putting a 0 at the end. i don't know if its a problem of my MIB's because if i want to monitor the load of my pc for 1, 5 or 15 min, for 1 min load: "1.3.6.1.4.1.2021.10.1.3.1" if i put a .0 at the end it doesn't gives me nothing. the same thing happens when i try to monitor AvailableRealMemory, AvailableRAMFree, RAMShared, RAM buffered...
      i don't know whats the problem or what i'm doing wrong
      thanks again!!
      • ghoz
        • May 2011
        • 204
        Don't worry, that's the way snmp works, for 'single items' it ends by .0
        for indexed or 'array' items, it end by an index, that can be anything, in the linux load example, it ends by .1, .2 or .3 meaning load for 1, 5, 15 minutes.
        • MrKen
          • Oct 2008
          • 652
          When searching for the correct OID, you should use snmpwalk.
          So, in your example for cpu load, do this: (notice that I don't put the 1 at the end)
          [root@zabbix etc]# snmpwalk -v2c -c public 1xx.xx.xx.xx 1.3.6.1.4.1.2021.10.1.3
          UCD-SNMP-MIB::laLoad.1 = STRING: 0.92
          UCD-SNMP-MIB::laLoad.2 = STRING: 0.91
          UCD-SNMP-MIB::laLoad.3 = STRING: 0.88
          Now you can use snmpget for
          1.3.6.1.4.1.2021.10.1.3.2
          1.3.6.1.4.1.2021.10.1.3.3
          MrKen
          • wikisb
            • May 2011
            • 64
            hi again!!
            i'm a bit fed up with all this things of MIB's and its tree structure.
            i have done a snmpwalk like the one you tiped MrKen and what i get is "End of Mib" & "No more variables left in this MIB View(It is past the end of the MIB tree)"
            i also tried in some values snmpgetnext. i did it to 1.3.6.1.2.1.25.3.3.1.2 and it gave me the value of hrProcessorLoad but trying it with snmpget to the "next" OID it didn't printed nothing of value isn't a wierd thing¿?
            i'm a bit lost.....
            and thanks a lot to try to help me!!
            • MrKen
              • Oct 2008
              • 652
              Yes it can be difficult to come to grips with.
              Maybe a good idea to check out these tutorials.
              SNMP Tutorials: http://net-snmp.sourceforge.net/wiki....php/Tutorials
              MrKen
              • wikisb
                • May 2011
                • 64
                hi again!!
                i have taken a look at some tutorials, posts & other things, but still i don't know what the heck is happening when i try to get a value for CPU average load or whatever other value after 1.3.6.1.4.1.2021. if i do snmpwalk or others commands to this OID or a child one, what i get is "End of MIb"
                HOW it shows me this thing instead of the values i am seeking??.
                also i tried to monitor other devices like printers, i have an Aficio MC2500 and i can't find where are the OID's of toner, paper. when i do a snmpwalk to the printer i get lots of values but without description i can't guess wich value is the one of toner capacity, paper tray, etc...
                the pc i try to monitor is a win Xp.
                its wierd that i can monitor disk space, usage, processes, services and i can't with all the 1.3.6.1.4.2021 childs
                thanks!!
                • ghoz
                  • May 2011
                  • 204
                  Welcome to the wonderful world of snmp... aka the wild west.
                  * For the CPU info, check you snmp.conf, if i remember correctly by default the net-snmp agent won't let you get anything but basic system info man snmpd.conf
                  * For printers and other devices, you have to seach for a MIB to get the translation for you OIDs. you may be lucky with a standard mib like PRINTER-MIB...
                  unfortunately, many constructors will use their own MIB and OID tree , meaning you have to search really hard for the info... I remember having to sniff a control pannel in order to find out by guess work what oid was the value I was looking for...
                  • ghoz
                    • May 2011
                    • 204
                    mmh.. btw that may be your problem ...
                    are you sure you don't have a problem between the net-snmp agent and the native windows one ?
                    • wikisb
                      • May 2011
                      • 64
                      hi ghoz!!
                      thanks again for posting!! i thought this page http://www.oid-info.com/index.htm was going to help me much but is not the case. so i will have to do "the dirty work" to find the values to monitor? OMfG...
                      in my winxp pc i have snmp (is there a snmp.conf¿?) and the MIB for cpu load and stuff it seems it doesn't exist. because by default it should be here: 1.3.6.1.4.1.2021. but my pc 2021 it says it doesn't exits in teh MIB either their childs.
                      i don't know if there is a problem between the native snmp and agent snmp, it seems it works fine except for the 1.3.6.1.4.1.2021... it also doesn't works in my linux server trying to get information from 1.3.6.1.4.1.2021 and its childs
                      • ghoz
                        • May 2011
                        • 204
                        the 1.3.6.1.4.1.2021 subtree is specific to net-snmp agents...
                        every device implements the trees it needs.
                        the defaulkt snmp on windows will not answer this oid tree ...
                        and good luck for your MIB searching...
                        anyway for windows you'd better off with a zabbix agent and standard items.
                        • wikisb
                          • May 2011
                          • 64
                          Ok Ghoz & MrKen thanks for your support & to make things easier.
                          i guess i have to learn deeper this protocol... #~$%'!!
                          i'm afraid i'm not going to use the zabbix agent because i'm told to use only SNMP.
                          thanks!!
