Error on creating an action in IE8
  • kkenta
    • Jun 2011
    Hi.
    I would like to know if someone managed to create an action with a trigger as its condition in IE8. Or, let me know if someone knows about this error and how to solve.
    In my case, it seems none of the triggers could be set as a condition of an action in IE8 (I haven't tried all, but it seems they produce the same result).
    When I selected a trigger in the list, nothing appeared in the box next to the "Select" button. Then, I filled other fields and clicked "Add" button, two error messages showed up:
    1. DBcondition Error: [Zabbix server:/etc/passwd has been changed on server Zabbix server] incorrect value for numeric field
    2. Incorrect trigger
    The actual procedure was:
    [Configuration]=>[Action]=>[Create Action]=>
    in "Action Conditions" [new] => select "Trigger" and click [Select] =>
    select "/etc/passwd has been changed on server Zabbix server" in the list(which is the default trigger) =>
    fill in the required fields => click "add"
    My environment:
    CentOS 5.5
    Zabbix 1.8.5
    PostgreSQL 8.1
    Internet Explorer 8
    Thanks in advance.
    Kenta
  • ServicesIt
    • Feb 2009
    • 19
    I have the same problem but also with IE 7
    Cannot add a trigger at all.
    • ServicesIt
      • Feb 2009
      • 19
      It works when using Firefox.
      I used portable version 3.5
