how to configure ssl certificate monitoring
Tags: None
This solution is based on external checks that are supported by Zabbix 1.4; however, it uses a macro to define the port to check.HI ,
we are using zabbix 1.4 , we need to configure ssl certificate monitoring.We have checked one of the relevent site, we need more details on how to configure and implement ssl cert monitoring for number of sites.
Since macros where not supported in Zabbix 1.4, you can either upgrade to a recent Zabbix version or modify the script to get rid of the macro.
Regards,
JBoComment
