proc.num retun diff value
  • cool_camel
    • Mar 2005
    • 9
    Hi all,
    I have zabbix agent on server running Oracle IAS to check the number of processes on RH3 with ps -ef |wc -l returnning 265 but with
    zabbix_get -sxxx.xxx.32.50 -p10050 -k"proc.num"
    909
    i tried same proc.num on rh4 reurned same value than ps -ef |wc -l ( no problem on RH4 and fedora 3/4).
    I am not sure how is proc.num returning the number of processes.
    also i tested the followgin on the rh3 returned
    proc.num[java]
    543
    on same machine i tried ps returned the following
    ps -ef |grep java |wc -l
    29
    I not sure if there is bug on the agent the agent version i using is 1.1beta6( same problem i had with 1.1beta5).
    Regard.
  • kempkep
    • Feb 2006
    • 18
    agent counts the threads with command name
    I noted the same 'problem', but have decided the difference is that the zabbix agent counts the number of threads with the required command name.
    Try issuing ps -efm | wc -l
    The numbers are surprisingly similar
    Now, what would be real handy would be for proc.num to be able to also search the command parameters.
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      It is already supported for Linux, but not documented yet. Fourth parameter to proc.num accepts command line
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
