User macro in trapper item does not expand
  • hansv
    • Jun 2011
    Hi there,
    I've setup a template with a user macro like so:
    {$PROCNAME} => zabbix_agentd
    In the template I've created a couple of items. One is of type zabbix-agent, having this key:
    sw.proc.status.procname[{$PROCNAME}]
    This fires a script that is defined as a UserParameter. The script does some work (gathers stats in /proc for a process (zabbix_agentd, in this example)) and sends data back with zabbix_sender.
    The rest of the items in the template are set up as type zabbix-trapper, like so:
    sw.proc.utime[{$PROCNAME}]
    sw.proc.rss[{$PROCNAME}]
    Now, the sw.proc.status.procname[{$PROCNAME}] expands to sw.proc.status.procname[zabbix_agentd], according to the server debug log.
    As soon as it queries the client, the client sends its data, like so:
    - sw.proc.utime[zabbix_agentd] 168
    The server responds with:
    info":"Processed 0 Failed 9 ...
    I suspect that the macro isn't being expanded here, as I thought it would.
    When I change this item to:
    to this:
    info":"Processed 1 Failed 8 ...
    So, it does work when the key parameter is set to a static value, instead of a user macro.
    Is this intentional, or am I hitting a bug?
    Edit: I'm using v1.8.4
    Cheers,
    - hans
  • FonTim
    • Jan 2013
    • 15
    I'm seeing the same issue on 2.2 still - did you get any resolution to this?
    • steveboyson
      • Jul 2013
      • 582
      Works here , both in 2.0.10 and 2.2.1
      (just a question: you are not using {$PROCNAME} within your script, right? What happens if you send the value manually via "zabbix-send"?)
      • FonTim
        • Jan 2013
        • 15
        Not the OP, but I raised a ZBX bug about this, and it got marked as a duplicate of a previous Won't Fix ticket.
        As you can see by my examples, I manually send with zabbix_sender and item with key trap.test[macro] with the server trapper item key trap.test[{$MACROTEST}] and {$MACROTEST} = macro in the host user macros.
        on the ticket, richlv suggests using LLD instead, so I am making my script emit the nessicary JSON items that it will later populate with zabbix_sender...
