fping on zabbix_proxy permission denied
  • saintxseiya
    • Oct 2010
    • 17
    Hi guys,
    i have a problem with fping on the zabbix proxy.
    i have some hosts taht should be monitored by the proxy and changed the monitoring server to the zabbix_proxy.
    no i get the same fault as i had it times ago on the server itself.
     1173:20110706:173200.245 Host [172.21.100.10] /usr/bin/fping: [13] Permission
      1173:20110706:173200.246 Query [txnlev:1] [update items set status=3,lastclock
      1173:20110706:173201.248 /usr/bin/fping: [13] Permission denied
    on the server i fixed it by changing the owner of the fping tool:
    chown root:zabbix /usr/bin/fping
    chmod 710 /usr/bin/fping
    chmod ug+s /usr/bin/fping
    This is not working for the proxy though!
    Has anyone an idea and can help me?
    Thank you!
  • saintxseiya
    • Oct 2010
    • 17
    Anyway, this is not the most active community here.
    So the solution was to setuid fping on the proxy allthough not necessary on the Zabbix Server itself:
    chmod 4755 /usr/bin/fping
    the commands have to be in this order.
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      fping is required only if you have any icmpping related checks like icmpping or icmppingsec. Otherwise you may not install it.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
