Actions status problem in node based setup
  • erikd
    • Feb 2011
    We have a problem with action status not being the same on master-server as on a slave-node in a node based setup.
    Viewing the node from the master shows "In progress" on action status but on the node directly it says "Ok" and it should be "Ok" since the action sent e-mail as intended.
