PID Issues...repost!
  • moo
    • Aug 2010
    • 22
    Think I posted in the wrong place last time so I'm reposting here (sorry!!)
    I'm pretty sure the solution to this problem is going to be really simple (it's happened to me before but can't for the life of me remember what I did!)
    Basically, logged onto the Zabbix FE this morning to find that the zabbix server wasn't running.
    So hopped onto the box that it should be running from & found the zabbix-agent threads running fine but no zabbix-server.
    So, attempted to start the service and got;
    * WARNING:  "zabbix-server" has already been started.
    I try and stop it and get;
    No process in pidfile `/var/run/zabbix/zabbix_server.pid' found running; none killed.
    I attempt to delete PID I get;
    cannot remove `/var/run/zabbix/zabbix_agentd.pid': No such file or directory
    Most recent logs only show;
     25300:20110729:010227.553 One child process died (PID:25307). Exiting ...
     25300:20110729:010230.014 Syncing history data...
     25300:20110729:010231.772 Syncing history data...done.
     25300:20110729:010231.773 Syncing trends data...
     25300:20110729:010253.577 Syncing trends data...done.
     25300:20110729:010253.586 Zabbix Server stopped. Zabbix 1.8.2 (revision 11211).
    There have been no permission changes on this box, & also it is mission critical (due to other services running on it) so I cannot reboot.
    Anyone had this problem before
