beta7 issue #2
  • crs9
    • Feb 2006
    • 35
    beta7 issue #2
    I created a host using a template and everything was created fine. When I deleted the host I got errors of:
    Error in query [select distinct c.actionid from conditions c, triggers t where c.conditiontype=CONDITION_TYPE_TRIGGER and c.value=t.triggerid] [Unknown column 'CONDITION_TYPE_TRIGGER' in 'where clause']Error in query [select distinct c.actionid from conditions c, triggers t where c.conditiontype=CONDITION_TYPE_TRIGGER and c.value=t.triggerid] [Unknown column 'CONDITION_TYPE_TRIGGER' in 'where clause']Error in query [select distinct c.actionid from conditions c, triggers t where c.conditiontype=CONDITION_TYPE_TRIGGER and c.value=t.triggerid] [Unknown column 'CONDITION_TYPE_TRIGGER' in 'where clause']Error in query [select distinct c.actionid from conditions c, triggers t where c.conditiontype=CONDITION_TYPE_TRIGGER and c.value=t.triggerid] [Unknown column 'CONDITION_TYPE_TRIGGER' in 'where clause']Error in query [select distinct c.actionid from conditions c, triggers t where c.conditiontype=CONDITION_TYPE_TRIGGER and c.value=t.triggerid] [Unknown column 'CONDITION_TYPE_TRIGGER' in 'where clause']Error in query [select distinct c.actionid from conditions c, triggers t where c.conditiontype=CONDITION_TYPE_TRIGGER and c.value=t.triggerid] [Unknown column 'CONDITION_TYPE_TRIGGER' in 'where clause']Error in query [select distinct c.actionid from conditions c, triggers t where c.conditiontype=CONDITION_TYPE_TRIGGER and c.value=t.triggerid] [Unknown column 'CONDITION_TYPE_TRIGGER' in 'where clause']Error in query [select distinct c.actionid from conditions c, triggers t where c.conditiontype=CONDITION_TYPE_TRIGGER and c.value=t.triggerid] [Unknown column 'CONDITION_TYPE_TRIGGER' in 'where clause']Error in query [select distinct c.actionid from conditions c, triggers t where c.conditiontype=CONDITION_TYPE_TRIGGER and c.value=t.triggerid] [Unknown column 'CONDITION_TYPE_TRIGGER' in 'where clause']Error in query [select distinct c.actionid from conditions c, triggers t where c.conditiontype=CONDITION_TYPE_TRIGGER and c.value=t.triggerid] [Unknown column 'CONDITION_TYPE_TRIGGER' in 'where clause']Error in query [select distinct c.actionid from conditions c, triggers t where c.conditiontype=CONDITION_TYPE_TRIGGER and c.value=t.triggerid] [Unknown column 'CONDITION_TYPE_TRIGGER' in 'where clause']
    Upon looking around the only issue I found was the graphs for that host were not removed, everything else appears to be gone. It shows the graphs there, but the host column is blank.
  • bbrendon
    • Sep 2005
    • 873
    Good to hear i'm not the first one upgrading.
    I always get a load of surprises when upgrading.
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • mconigliaro
      • Jun 2005
      • 116
      i can confirm this problem.
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Thanks for reporting this. In order to fix replace:
        " where c.conditiontype=CONDITION_TYPE_TRIGGER".
        by
        " where c.conditiontype=".CONDITION_TYPE_TRIGGER.
        in triggers.inc.php
        Fixed in CVS.
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
        • crs9
          • Feb 2006
          • 35
          thanks for the quick fix. My question is I assume it fixes the error mesage, am I correct in assmuning the graph deleting is a different problem?
          • Alexei
            Founder, CEO
            • Sep 2004
            • 5654
            Removal of graphs is a different issue. I cannot confirm if it really exists yet.
            Alexei Vladishev
            My Twitter
            • haxor
              • Jul 2005
              • 11
              warning messages
              I did that fix which took care of the errors, but I still get a bunch of warnings that are all the same. they are:
              Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in /var/www/localhost/htdocs/zabbix/include/db.inc.php on line 111
              and ideas?
