Launch only one action.
  • candidinho
    • Jul 2011
    Hello everybody.
    I'm monitoring bandwitch on a local lan. I set triggers that run when the bandwith is up to 100kb per second.
    My problem is:
    The bandwitch is too inestable and the values change every sencond between 0 - 200kb per second. Because that, y receive a lot of triggers of the same item. And a lot of actions based on the same item, too.
    How can i launch only one action based on this item?
    How can i define a way to the triggers stay up until i disable it manually?
    Thanks.
  • Mojah
    • Apr 2010
    • 60
    It's best to make your triggers based on the average value of the last 10 minutes or so, instead of the last value you have received.
    So try changing your triggers to .avg(600)>xx instead of .last()>xx.
