Agent polling problems. Item status
  • Gigoudt
    • Sep 2010
    • 22
    Hi to everyone!
    I am having a problem with some servers that we are monitoring
    We are using passive agents to monitor them. There are a lot of agent, simple and external items in the template.
    The strange thing is that after a problem is solved sometimes a server doesnt go up. The status item stays in 2 and every agent item does not update.
    The agent on the server is working ok. Whit zabbix_get we can collect data.
    I know how the status item works. My question is if the server wont start collecting zabbix agent items again if host status goes up again ? The hosts item also is used to determine unreachable of a host ? It is related?
    If I turn down the agent, wait some minutes and then start it again the central server start monitoring all data again. This method is not a solution because we have more than 500 servers...
    We are plannig to eliminate the status item and use a no data () trigger. This will eliminate the problem of the not updating agent items ?
    thanks to all. Hope if someone could give a clue !!
    Andres
    p.d Sorry for my English
  • Gigoudt
    • Sep 2010
    • 22
    anyone help ?!
    thanks
    • ghoz
      • May 2011
      • 204
      Maybe something related to the following configuration options on the server ?
      UnavailableDelay : How often host is checked for availability during the unavailability period, in seconds.
      UnreachableDelay : How often host is checked for availability during the unreachability period, in seconds.
      http://www.zabbix.com/documentation/.../zabbix_server
