Still having problem monitoring site now with 1.8.6
  • dpbaker57
    • Aug 2010
    • 33
    I keep getting an "Failed on "Status Page" [1 of 1] Error: SSL connect error" error monitoring https://express.rwsol.com/roi/servle...yAction=Status
    All that the site should come back with is "Status: GREEN"
    I've attached screen captures of my configuration.
    This has been happening since at least 1.8.3
    The server log shows:
    11506:20110819:104648.740 Web scenario step [WPIFP_Status_Page: DisplaySystemStatus] error: error doing curl_easy_perform: SSL connect error
    11506:20110819:104848.310 Web scenario step [WPIFP_Status_Page: DisplaySystemStatus] error: error doing curl_easy_perform: SSL connect error
    11506:20110819:105055.260 Web scenario step [WPIFP_Status_Page: DisplaySystemStatus] error: error doing curl_easy_perform: SSL connect error
    11506:20110819:105256.314 Web scenario step [WPIFP_Status_Page: DisplaySystemStatus] error: error doing curl_easy_perform: SSL connect error
    {I put a space between the colon and the capital D above to keep them from becoming }
  • Yello
    • Apr 2011
    • 309
    I got an error like this and it was caused by firewalls. Have you validated the request from the command line?
    Regards,
    David
    • dpbaker57
      • Aug 2010
      • 33
      Works from command line
      I tried it with curl and lynx and got the expected results.
