PHP frontend pg_connect broken. *previous threads didn't solve*
  • incite-guy
    • Aug 2011
    Hi guys,
    I'm trying my second POC where the webui, Zabbix server & PostGre are all dedicated. When I try to configure the PHP front end I keep getting:
        pg_connect(): Unable to connect to PostgreSQL server: could not connect to server: Connection timed out Is the server running on host "10.10.10.71" and accepting TCP/IP connections on port 5432? [include/db.inc.php:81]
        Error connecting to database
    The 1.8.6 zabbix server is connected to the PostGre 8.4.7-1 server using the 'zabbix' user & my password as recommended so I know credentials & SQL connection settings are correct. I've even cut and paste across SSH terminals to be sure.
    I've tried disabling IPTables & SELinux on the Apache system with no change.(IPTables is up on the PostGre server but configured properly since the Zabbix server runs)
    Anyone have any ideas? I'm fresh out.
    Thanks!
