Upgrading to zabbix 1.9.6 beta failed
  • frater
    • Oct 2010
    • 340
    Upgrading from 1.8.5 to 1.8.6, 1.8.7, 1.8.8beta and 1.8.8rc1 went smooth each time.
    But my latest upgrade just now to 1.9.6beta failed after I used the supplied script to upgrade the database.
    Maybe someone knows what I'm doing wrong or how I can fix this.
    I know "This is an UNSUPPORTED Zabbix upgrade script from 1.8 to 2.0". Does this mean I'm #$% ??
    I guess I need to do a fresh install of 1.9.6 and import all the XML-files
    root@zabbix:/opt/zabbix-1.9.6/upgrades/dbpatches/2.0/mysql# ./upgrade -p zabbix
     WARNING: backup your database before performing upgrade
     This is an UNSUPPORTED Zabbix upgrade script from 1.8 to 2.0 for MySQL
     It does the following things:
      1. Updates indexes that might require changes;
      2. Patches the database from 1.8 schema to 2.0 schema;
      3. Adds 'Disabled' and 'Debug' usergroup if any missing;
      4. Checks for hosts not belonging to any group and adds them to one if any found.
     Usage: pass required MySQL parameters to this script (like database, user, password etc).
    Continue ? (y/n) y
    Dropping indexes that might need re-creation...
    Enter password:
     ... dropping of indexes took 0:00:05
    Creating possibly missing indexes...
    Enter password:
    creating of indexes took 0:00:05
    Patching the database
    Enter password:
    ERROR 1005 (HY000) at line 6: Can't create table 'zabbix.#sql-1e3_414' (errno: 121)
    Failed to patch Zabbix database. Restore from backup
    Zabbix agents on Linux, FreeBSD, Windows, AVM-Fritz!box, DD-WRT and QNAP
  • frater
    • Oct 2010
    • 340
    I completely configured a new server, but I need to add all my custom items by hand because the old installation is a bit #$%^#^.
    I can't see the triggers anymore and the export files are incomplete...
    If someone knows how I can get that server going somehow, please let me know.
    • richlv
      • Oct 2005
      • 3112
      first, 1.9.6 is a development release. it has some hundred serious bugs - and i'm serious.
      additionally, there is no guaranteed database compatibility with further 1.9 releases.
      nevertheless, the db patch should work fine... was that an unmodified 1.8 database ? did you run the upgrade patch only once ?
      can you paste line 6 from patch.sql, just to be completely sure ?
      as for solving your current situation - you restore a db backup you made right before attempting to patch the database.
      • frater
        • Oct 2010
        • 340
        Embarrassed to admit that I don't have a backup of the database...
        I lost all the trigger information and I had to create all the custom items by hand. The historical data is not that important really, but I had a nice balanced item/trigger set-up with dependencies.
        I really wanted the feature {HOST.CONN}.. in trigger names which wasn't added to 1.8.8rc1, so I upgraded.
        The first thing I noticed after upgrading:
        • External scripts get the parameters in a different way
        • API access is disabled or different (MoZBX doesn't work anymore)
        • richlv
          • Oct 2005
          • 3112
          yep, as briefly noted in the draft document at http://www.zabbix.com/documentation/...ameter_changes
          it's enabled for all users by default now, but probably something has changed. all changes are supposed to be documented at http://www.zabbix.com/documentation/...nges_1.8_-_2.0
          • frater
            • Oct 2010
            • 340
            OK, that's an improvement...
            But I already wrote some workaround to handle the behaviour on CLI and zabbix.
            Could you set an environment variable (for instance ZABBIX=1.96) which will enable me to write scripts that work in both 1.8 and newer versions....
            I'm now using the current path...
            • richlv
              • Oct 2005
              • 3112
              please, split out this question in a separate thread
              also, clarify what is the workaround, um, working around exactly.
              • frater
                • Oct 2010
                • 340
                I'm sitting on a terrace celebrating my birthday but still nerd enough to check this thread. I Can explain better tomorrow, but meanwhile this thread could already explain things.
                t
                i
