Issue monitoring if file timestamp is modified
  • aic
    • Oct 2010
    • 50
    I am using Zabbix version 1.8.3 over Linux and I am in trouble to check if modified or not in the last 5 minutes.
    When I added an key like that I got an error and finally I didn't do it:
    {hostname:vfs.file.time[/file/to/mon.log.0,modify].fuzzytime(60)}=1
    So I implemented the following but I am not so sure if this is the best way to do it. Following the documentation I am not happy with the results:
    {hostname:vfs.file.time[/file/to/mon.log.0,modify].diff(0)}=0
    FYI: I dicided not to use vfs.file.chksum because most of the time the file is empty, is not like /etc/passwd...
    Maybe I just need an extra pair of eyes
    Thank you for any help!
  • frater
    • Oct 2010
    • 340
    Isn't {hostname:vfs.file.time[/file/to/mon.log.0,modify].diff(0)}=1 doing what you want (you have 0)?
    Zabbix agents on Linux, FreeBSD, Windows, AVM-Fritz!box, DD-WRT and QNAP
    • aic
      • Oct 2010
      • 50
      Thanks for you reply.
      I changed 0 by 1, the file has not been modified in the last hour and there is no news about the Trigger alerting that the file was not modified in the last 5 minutes
      • Ori0n
        • Dec 2010
        • 35
        The logic seems sound. Have you verified the actual item itself (vfs.file.time[/file/to/mon.log.0,modify]) is working as expected?
        • frater
          • Oct 2010
          • 340
          You wanted a trigger to see if the file hasn't changed...
          I didn't get that...
          If you go to 'latest data' can you see the item change?
          You have an item named "vfs.file.time[/file/to/mon.log.0,modify]" ?
          • aic
            • Oct 2010
            • 50
            Checking the "Latest Data" details I can see the monitor run correctly. I am seeing this:
            Monitor Status Master 20 Sep 2011 15:55:40 1316544914
            Now I changed the interval of checking from 30 seconds to 300 second too.
            • frater
              • Oct 2010
              • 340
              If you use diff you should set the interval to 300
              Does it work now?
              If not... does this one work?
              vfs.file.time[/file/to/mon.log.0,modify].last(#1)}=vfs.file.time[/file/to/mon.log.0,modify].last(#2)}
              I'm not sure, but if I understand the manual correctly this should work when the interval is less than 300
              vfs.file.time[/file/to/mon.log.0,modify].last(0)}=vfs.file.time[/file/to/mon.log.0,modify].last(0,300)}
              I'm interested in the results
