{TIGGER.KEY} Question
  • SAT QPass
    • Oct 2005
    • 61
    From the Wiki and my reading in the forums, I was under the impression that given the Trigger Expression:
    {__ZABBIX.database:zabbix[items_unsupported].min(90)}#0
    The TITLE of the trigger is as follows:
    {HOSTNAME} :: ZABBIX CONFIGURATION :: {TRIGGER.KEY}
    So now my question....
    It is my understanding that the macro {TRIGGER.KEY} *should* expand/replace with "zabbix[items_unsupported]" when viewed in the triggers configuration page.
    Instead I see the following:
    __ZABBIX.database :: ZABBIX CONFIGURATION :: {TRIGGER.KEY}
    Thanks to everybody for their time and consideration. Forgive me if this has been asked before.
    Aaron
    Last edited by SAT QPass; 07-03-2006, 19:13. Reason: Fixed "what I see so it did not have duplicate {TRIGGER.KEY} for some reason...
  • bbrendon
    • Sep 2005
    • 873
    Aren't you talking about actions?
    I think you'll only see the desired effect when the trigger/action actually runs.
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • SAT QPass
      • Oct 2005
      • 61
      Actually {HOSTNAME} works correctly in Trigger TITLE configuration form. When viewed in the trigger list, one sees {HOSTNAME} replaced with whatever the hostname is.
      I was hoping that I could save myself some typing by using the {TRIGGER.KEY}, which would simply things in my opinion and having that displayed correctly in the trigger list. I guess that does not work in triggers, but does in actions.
      Aaron
