disabling nodata tricker after host not monitoring
  • fips
    • Sep 2005
    • 38
    Every time if I disable the monitoring of a host for more then the time specified in the nodata trigger, I will get a trigger action if I reenable the host.
    Example: {PC:icmpping.nodata(300)}=1
    Disabling the host for more then 5 minutes will trigger an action. The behavior is logical correct, but I dont like to have this trigger action, because it was me who disabled the host for monitoring.
    Is there some way to enable a trigger after some time? Can I get the value for host enabled time? Some other suggestion on how to surpress the fist trigger action after enabling the host?
    Thanks for help!
  • fips
    • Sep 2005
    • 38
    no one has this problem
    No one has this problem, or no one ever tried to disable a host with a trigger like this for 10 minutes:
    {Template_Linux:agent.ping.nodata(600)}
    For me it is the same problem as mass alarms after enabling zabbix server. I really like to know how i can suppress the trigger firing after enabling the host in the zabbix web gui!
    • HullZabbix
      • Feb 2011
      • 104
      I don't get this problem on any of my items.
      Though I'm using
      {TemplateServers:icmpping[].nodata(180)}=1
      Notice the []. I've no idea if this makes a different, but it may help
      • fips
        • Sep 2005
        • 38
        icmpping not working too
        Hello
        I tried your trigger and I have the same problem as with agent.ping.
        Did you disable your host for more then 180 seconds to test it will trigger afterwards?
        Thanks for your reply anyway. Maybe I have to find out what is wrong with my 1.8.8 version.
        And here the prove:
        • HullZabbix
          • Feb 2011
          • 104
          Yes I disabled it for longer 180.
          I'm on 1.8.6
          Sorry I can't be of further help
          • fips
            • Sep 2005
            • 38
            same problem on new install
            I installed zabbix on a new virtual machine and I get the same probem!!!
            • robertkarl
              • Aug 2012
              Solution ?
              Did you ever get a solution on this ???
              I have the same problem...
              When I put a host on maintenance period for more than 5 minute, trigger nodata fire it up when the maintenance is over... very annoying,.
