Zabbix 1.8.8 - Error send SMS
  • anan25vn
    • Sep 2011
    Hi all,
    I have Zabbix based on CentOS 6. I added GSM modem for sending SMS.
    But it doesn't work. It show :
    Expected [OK] received []
    Do you have any idea ?
    Cong
  • eskytthe
    • May 2011
    • 363
    For more details please look here - from the zabbix GUI:
    Administration - Audit - Choose "Actions" at the upper rigth
    Maybe you also have to check zabbix server log or/and some linux logs.
    BR
    /Erik
    • anan25vn
      • Sep 2011
      Hi Erik,
      I show log of zabbix_server, it has no info about send sms.
      You can open attach images to view more info.
      I can send by AT command when log on minicom - GSM modem
      Sorry about my english.
      Cong
      • anan25vn
        • Sep 2011
        It likes the problem on link below :
        But on zabbix-1.8.8 folder, I can't find sms.c
        Where is it ?
        Cong
        • eskytthe
          • May 2011
          • 363
          Hi Cong
          I do not know how to help you further. …
          Seems like zabbix do some attempts to talk with your sms system but do not success.
          Maybe:
          - Turn debug on in zabbix server log?
          - Try to run your sms software as zabbix user? (permissions / path problem?)
          - Sms software log? / linux logs?
          - Try ask on the IRC zabbix forum.
          Br
          Erik
          • 0siris
            • Nov 2010
            • 76
            Is the GSM modem indeed on /dev/ttyS0? Is the right kernel module loaded?
            Has user "zabbix" enought rights on that device?
            • anan25vn
              • Sep 2011
              Hi 0siris,
              I grant full permission on GSM modem to zabbix user
