zabbix monitoring issue - fresh install
  • alberte
    • Oct 2011
    • 18
    ok one problem after another...
    i did a fresh install of cent os and zabbix.
    i setup the agent on the server and windows however nothing is being populated. the z icon is grayed out when its suppose to be green.
    any ideas? getting kinda of frustrated since i made about 16 posts so far and got only 1 response so far....
  • walterheck
    • Jul 2009
    • 153
    Well, if you have problems that you want a quicker answer to, come and visit us on #zabbix on Freenode in irc, it's a bit quicker way to get support.
    To get to the bottom of this problem, it's best to check your log files on both the agent and server side. They will tell you more most likely.
    Free and Open Source Zabbix Templates Repository | Hosted Zabbix @ Tribily (http://tribily.com)
