Trigger max dont' work
  • frarosati
    • Mar 2006
    i try to set my trigger on item icmpping to max(300)=0
    bu it doesn't work . The trigger is always off.
    If in the trigger I set last(0) the trigger work corretly.
    Doo You have any ideas ?
    regards
    Francesco
  • sauron
    • Jan 2005
    • 215
    Yes. This trouble got two solution.
    1. Change data type from int64 to float
    2. Get patch from this http://www.zabbix.com/forum/showthread.php?t=2246 apply this and rebuild zabbix-server.
