working, thanks a lot
Zabbix server is running = no
No problem
I haven't tested whether this change survives a reboot or relabel. I'll test this now and let you knowComment
Doesn't survive a reboot
I even tried removing the access to the port with
semanage port -d -t http_port_t -p tcp 10051
Restarting Apache and adding the permission again. I'll work on this over the weekend, for now this is what I'm getting in /var/log/audit/audit.log:
type=AVC msg=audit(1323442115.704:20): avc: denied { name_connect } for pid=1421 comm="httpd" dest=10051 scontext=unconfined_u:system_r:httpd_t:s0 tcontext=system_u
bject_r
ort_t:s0 tclass=tcp_socket
Oops I'm an idiot
Yes, it does work after a reboot, I had forgotten to set zabbix-server to start automatically...Comment
Modifying SELINUX to make it work
The root cause of this problem is because SELINUX enforcement..
you can check the selinux log, every time the zabbix agent tries to check whether zabbix server is running, it causes a violation on SELINUX.
For checking SELINUX violations:
tail -f /var/log/audit/audit.log |grep -i avc
you should get something similar:
type=AVC msg=audit(1327136033.974:16979): avc: denied { name_connect } for pid=30840 comm="httpd" dest=10051 scontext=unconfined_u:system_r:httpd_t:s0 tcontext=system_u
bject_r
For adding the policy:
(From http://www.centos.org/modules/newbb/...?topic_id=8696)
[root@example]# audit2allow -a -m local > local.te
[root@example]# checkmodule -M -m -o local.mod local.te
checkmodule: loading policy configuration from local.te
checkmodule: policy configuration loaded
checkmodule: writing binary representation (version 6) to local.mod
[root@example]# semodule_package -o local.pp -m local.mod
[root@example]# semodule -i ./local.pp
After this restart the zabbix-agent and it works now without disabling SELINUX
Hope this helpsComment
selinux blocks snmptrap.sh
Hi all!
Does anybody know how to create a police to allow snmtrapd to execute snmptrap.sh script? And where is to be placed snmptrep.sh script? Rihard Olups in "Zabbix 1.8 network monitoring" place it to /home/zabbix/bin/. Is it secure?
Testing snmptrap.sh I run:
after that I run:Code:snmptrap -Ci -v 2c -c public localhost "" "NET-SNMP-MIB::netSnmpExperimental" NET-SNMP-MIB::netSnmpExperimental s "test"
and got such an output:Code:grep snmptrap /var/log/audit/audit.log
sestatustype=AVC msg=audit(1327312258.773:80712): avc: denied { read } for pid=15854 comm="bash" name="snmptrap.sh" dev=dm-0 ino=150920 scontext=unconfined_u:system_r:snmpd_t:s0 tcontext=unconfined_u
bject_r:home_bin_t:s0 tclass=file
SELinux status: enabled
SELinuxfs mount: /selinux
Current mode: enforcing
Mode from config file: enforcing
Policy version: 24
Policy from config file: targetedComment
Hi I'm implementing a zabbix server on the corporation I work. All tests i have made with zabbix on VMs have worked. But, now I'm configuring it on a real host and on the dashboard It keeps showing that zabbix server is not working. I already have checked server log and apparently there is no error message.
Can someone give me a hande trying to fix this? Thank you.
I am also experiencing the same issue. I was reading through your post and you said disabling SELinux is the solution to the problem.
May I know if you also had the same Configuration-Hosts (Notice the Availability, Zabbix Agent seems to be greyed out.)Last edited by jsantiago; 02-10-2012, 04:35.Comment
Hi guys,
I get this error:
and this one:Code:8909:20120813:153713.521 Starting Zabbix Server. Zabbix 2.0.2 (revision 29214). 8909:20120813:153713.522 ****** Enabled features ****** 8909:20120813:153713.522 SNMP monitoring: YES 8909:20120813:153713.522 IPMI monitoring: NO 8909:20120813:153713.522 WEB monitoring: YES 8909:20120813:153713.522 Jabber notifications: NO 8909:20120813:153713.522 Ez Texting notifications: YES 8909:20120813:153713.522 ODBC: NO 8909:20120813:153713.522 SSH2 support: NO 8909:20120813:153713.522 IPv6 support: YES 8909:20120813:153713.522 ****************************** 8909:20120813:153713.538 listener failed: socket() for [[-]:10051] failed: [22] Invalid argument
this:Code:8915:20120813:153740.062 Starting Zabbix Agent [Zabbix server]. Zabbix 2.0.2 (revision 29214). 8915:20120813:153740.066 listener failed: socket() for [[-]:10050] failed: [22] Invalid argument
didn't help.
any ideas?Comment
zabbix-server and zabbix-agent didn't start.
when I try:
I get:Code:./zabbix-server start
but, if I try restart it, I get:Code:Starting Zabbix server daemon: zabbix_server
I was looking in syslog, but there is nothing about this.Code:Stopping Zabbix server daemon: zabbix_server No zabbix_server found running; none killed. Starting Zabbix server daemon: zabbix_server
EDIT:
I don't see zabix in running processes.Last edited by mir.jar; 14-08-2012, 15:22.Comment
selinux boolean will do the trick as well
Disabling SELinux is a bad idea all around. Not sure why people keep suggesting it.
daguirre81 is right with the policy. But there is a much easier way. Just enable the boolean httpd_can_network_connect.
setsebool with -P will persist the change across reboots.[root@local]# getsebool httpd_can_network_connect
httpd_can_network_connect --> off
[root@local]# setsebool httpd_can_network_connect on
httpd_can_network_connect --> onComment
What exactly do you mean? "getsebool" and "setsebool" are SELinux api commands. You shouldn't have to touch any files.Comment
