Hello everybody,
I have configured items to monitor several processes on a Windows host. All of them work properly except one.
It is configured as:
server
roc.num[DataGenerator.exe]
the alarm should rise when the host is not running any process with that name:
{server
roc.num[DataGenerator.exe].last(0)}<1
Well, the problem is that Zabbix rises the alarm even with the process being running.
I attach a PDF file so you can compare two items configured exactly the same way. "autocall.exe" works fine, but "DataGenerator.exe" doesn't.
¿why can this be happening?
Thanks in advance!
server
roc.num[DataGenerator.exe]the alarm should rise when the host is not running any process with that name:
{server
roc.num[DataGenerator.exe].last(0)}<1Well, the problem is that Zabbix rises the alarm even with the process being running.
Thanks in advance!
